KATwo40 »
https://forums.nicoclub.com/katwo40-u25350.html
Fri Feb 18, 2005 9:28 am
Hmmm, interesting.
I've never needed to be stealthy about what I'm packin' under the hood, since we don't have Nazi's here in TN for police, and if someone wants to know, I just don't open the hood.
As for more options, I doubt that seriously. With the vast array of turbochargers available today, you'd be a complete failure as a person if you couldn't find a rediculous amount of turbo options based on a T3/T4 footprint.
Sidemount: That's an interesting idea. However, how can this balance the engine anymore than a topmount or bottom mount? If I'm not mistaken, the further outward a weight is placed, the more leverage is has, applying more stress to the base at which it's attached. Besides, if you want a tubular manifold for the most efficient flow, forget the sidemount. I don't see that happening. Not that log manifolds are bad. There are a lotta high hp log setups goin' out there. Plenty to school my little pavement slapper.
Underhood temps: I don't really see how you're lowering the overall underhood temp, since the bottom mount is tucked under a gob of pipes and still doesn't get much airflow. A well placed scoop in the hood or some decent turbine wrap can easily displace the heat. I'd go with a turbine wrap, first, though. You'd be insulating the heat energy within the housing, thus making the operation of the turbine more efficient, while simultaniously lowering underhood temps.
Just my 2 cents. Bottom line is this:
Get what you want and can afford. Then, toss out everything everyone else tells you when you reach the point where you smile while you drive.
