bassboost »
https://forums.nicoclub.com/bassboost-u83773.html
Mon Jan 05, 2009 7:03 pm
Okay, so during a troubleshooting session on the SR. I had mocked up my 60-1 turbo on a ebay top mount turbo manifold. And from what it looks like, the turbo is basically sitting on my brake master cylinder. How do I avoid this problem? I'm sure it's not a good thing for that turbo to be so close to the brake master cylinder of all things. Also, other than the turbo rubbing, I purchased a 38mm Tial Wastegate which also looks like it will not fit either, it's aiming right into my lower part of the strut tower.
If I were to purchase a log style manifold would it be able to fix these fitment problems, with the turbo and wastegate?
Turbo Specs:
Inlet Size 4"Outlet Size 2.5"Compressor .70 AR CompressorTurbine .63 AR TurbineType of Flange T3Type of Down Pipe Flange Stand 5 Bolt
