dee said he ran that and it was a little big, and said the to4b would be better. i want as little lag as possible but still have a turbo i can take up to like 350-400 hp in the coming years.CA19DET wrote:the TO4E is a better compressor housing and wheel for a T3/T4 combo, flows more and will make more power/more efficent.
Stage 3. 360 bearings too if it's an option.originalsin wrote:dee said he ran that and it was a little big, and said the to4b would be better. i want as little lag as possible but still have a turbo i can take up to like 350-400 hp in the coming years.
any recomendations on what wheels i should run? im getting a garrett turbo and have the opion of wheels stage 1 to 3
I got 318.5whp on a T3/T04B stage 1 with a .60 front housing and .63 rear housing. The car spooled-up full boost at or around 3800rpm and that was using a stock manifold with a T3 flange mated to it. I beat-up some nasty cars with this combo which ultimately nearly cost me my life whilst racing on the highway. If your budget is low and you're notinterested in too much lag, then this turbo is the shiz-nit. But if you want to do 360+whp without pissing off the turbo, then you may want to consider a T3/t04E option.iliketocrash wrote:i talked with the people from turbonetics for about an hour and they eventually reccomended me to the stage 2 turbine. then again that was for my specific application. i also am using a baby .48 ar turbine housing :-) btw, this is on my t3/to4b and i don't know if my turbo is good to 400whp either. however i do know it's good to about mid 300's whp. I THINK.
