JGY Customs makes a rail that will work with a stock fpr. I have the version for the aeromotive and while its cool and all, its a ***** to hook up and takes about 70 dollars worth of AN fittings/fuel pressure gauge in addition to the cost of the fpr. If I could do it over again, I'd have gone with the stock regulator. If you do this, I think its worth it to go top feed over side feed. Once you factor in the cost of fittings, braided stainless line, fpr, and gauge then it takes the advantage away from the cheaper injectors. The cheapest place to get 72# injectors I know of is
http://www.racetronix.com just ignore the fact that it says 75#, they are identical to MSD 72's (I had one flow tested to find out).
