WDRacing wrote:Sidefeed's suck...period.
Topfeed's don't leak, they are easy to change, the fuel rail is only 30 bucks at project silvia...no reason not to convert. Find a buddy that wants a set of injectors, then order 8 from Summit...done and done.
DO IT OR BAN
WD, i know that you know your **** but DAMNNN. i'm getting a headache now.....
this what scott said "I highly recommend the Tomei / Nismo 740cc injectors. They are thebest in that range. Cost is a bit more but they will drop into yourstock rail with no problem and they run so much better than the topfeeds."
thats the guy who's tuning my ecu.
Plus the silviaproject fuel rail have to be custom to fit MSD injectors. such as machined to fit the hole to fit the MSD injectors...
