WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Fri Jun 02, 2006 10:54 am
I have a Aeromotive rail for the 4.6 mustang installed right now, I bought a set though...lol. They were expensive but flow enough to support about 1000000 whp. The injector spacing is almost perfect, one of the injectors, the #1 or #4 I can't remember, will sit at a small slant, but mine never leaked. I run 50lbs of static fuel pressure and 20lbs of boost...er should I say ran, now I have a hole in the block.
I'm currently "deployed" sort of speak, so I haven't been able to post much. I'll be back in October.
You'll have to fabricate new mounts. I'd go with side feeds like IWannaS15 said. WD
