I took my mate Andrew Baird, the mechanic round to see my car last night . The car had been sitting for around a week so it was started from cold. It sat idling for a couple of minutes, as has happened in the past, I told Andrew it would start to make noise soon . It came up to temp with no noise from the top end , I was quite suprised although very pleased.
Andrew explained what could have possibly happened; when i've been at full throttle crossing the finish line, it's overboosted and when the pipes have blown off the inlet manifold it's turned to max vaccum and sucked oil from top end ie the lifters.
Whats your opinion on this? I started it up the next day and everthing seems fine even under boost . Andrew's going to do a leakdown test on Friday so i'll put results up .
