newbe40 wrote:Thanks for your reply, I think you have given me some good advice about the turbo eg my stage 2 and housing. I was hoping to confirm what I thought to be the problem I will be calling the turbo builder on Monday !Would you have a good Idea of what total timing should be on pump gas 93 octane.
You didn't answer what you're base timing (at the distributor) is set at, nor if you have any tuning beyond the actual ECU...That'd be helpful in seeing what the problem is.
When I get home in like 2 weeks (where the car is, i'm at school), I'll data-log the timing at different RPMS/gears with my Blitz R-VIT to let everyone know what the JWT ECU programmed for 50 lb fuel injectors does for timing maps. (I'm using a Cobra MAFS, not a Z32, BTW).
I data-logged the timing when I had the JWT ECU programmed for 370 cc injectors, and even then the timing was pretty damn conservative, so I immediately advanced it 2 degrees to 22 deg BTDC. I believe one of the PRINCIPAL differences between the JWT ECU tune and the Enthalpy tune is the more advanced timing of the latter...it makes a big difference.
As for the turbo: does it hold boost consistently across the rev-range (in your case, up to 6000 rpm), or does it wane toward the upper rev-range (as was the case with my .48 a/r turbine)? Looking at your graph, the fact that the power does not drop but flattens out completely would indicate to me that you aren't losing boost...
I'm shooting for 300 whp @ 15 psi with a similar set up when I get home and dyno it so I hope part of your low power is due to the small turbo, conservative timing, and rich a/fs...My timing will probably be more advanced (yay methanol injection), and fuel pressure bumped down maybe 3 psi to lean it out a bit compared to yours though. If I'm able to get the a/fs in the 12 range, keep the timing at 22 or even 23 deg btdc depending on how much retarding the JWT ECU really does, and run with an open exhaust (I have an electronic cut-out after the downpipe, so it'd be like running just an open downpipe), I should be able to easily make 300 rwhp @ 15 psi, which is all I want. I also have an ASP crank pulley, fidanza flywheel, ACT street clutch, 1 mm oversized ferrea intake/exhaust valves, 3 angle competition valve job, and PDM stage II cams, and relatively high CR 9:1 wisecos....but the methanol injection will really let me run what others who don't use methanol would consider "lean" or "aggressive"....it really makes a huge difference. When I first turbocharged the car, I was running 10 psi (smaller T3) for over a year w/o an intercooler, just methanol injection, and it never once pinged. But I digress; this is all bench-racing...you need to make some changes with your set up and tell us how it goes.
For the record, S14tat made 300 rwhp from a similar set up as both of us (JWT ecu, Z32 MAFS), but with a larger turbo and an s-afc, but he said his a/fs were still mid-to-low 11's...and he's running base timing of 20 btdc as well. If his A/Fs were around 12:1 - 12.5:1, and he was running 22 deg btdc, I'm sure he'd have made around 320 rwhp, which is more like he should be making at 15 psi.
Modified by MarkEmark at 12:28 AM 4/30/2006
