elwesso wrote:So I am working on an article for the home page, and I have come up with a list of 20 fairly common "vehicle maintenance myths".. My intention is to write a little bit about each one with an article, but I need everyone's help here voting on the order.. So, in no specific order, here is the list:
PICK YOUR TOP 3
Tires are tires, get the cheapest ones you can find
Nitrogen inflated tires give you better fuel economy
You will void your new car warranty if you take it somewhere other than a dealer
Using synthetic oil in a high mileage engine
Wider tires gain you more traction
Optima batteries are worth the extra money
Tire Pressure- what the mfg. recommends, and what to do if you change tire size
“Lifetime” fluids are bogus
Car washes in winter driving/rust prevention techniques
Oil Change Intervals
Rubber parts wear out with mileage.
Chassis lubrication
Using the A/C will hurt your fuel economy
Premium gas is better for your car
Using Fuel Additives are good
For cars that are stored for long term, it’s good to periodically start them
After a jump start, the alternator will quickly recharge your battery
The tune up
Driving with a truck with the tailgate down increases fuel economy
You should warm up your car before driving
If you have any additional ones you'd like to add, let me know! I don't really want to discuss these topics individually, what I do want to know is everyone's TOP 3 PICKS
I second this set!dre1507 wrote:1. tires are tires
2. you should warm up your car before driving
3. premium gas is better for your car
For ball bearing turbos it's less important. It all has to do with heat buildup, so if you idle the car a little bit regardless it will help remove some of that residual heat. Also using synthetic oil helps that too..Jesda wrote: Does anyone know if modern turbos still benefit from idling before shutdown?
Using synthetic oil in a high mileage engine- I feel like this helps keeping my engine from breaking down and burning the oil as quickly as conventional.elwesso wrote:So I am working on an article for the home page, and I have come up with a list of 20 fairly common "vehicle maintenance myths".. My intention is to write a little bit about each one with an article, but I need everyone's help here voting on the order.. So, in no specific order, here is the list:
PICK YOUR TOP 3
Chassis lubrication
The tune up
[youtube]http://www.youtube.com/watch?v=DlN2G0ytanY[/youtube]elwesso wrote:For ball bearing turbos it's less important. It all has to do with heat buildup, so if you idle the car a little bit regardless it will help remove some of that residual heat. Also using synthetic oil helps that too..Jesda wrote: Does anyone know if modern turbos still benefit from idling before shutdown?
30 seconds - 1 minute is probably adequate for most applications... Just don't shut off the car before you turn down your Ace of Base cassette and grab your man purse...
That's a good one. I actually just researched that a few days ago, the lowest freezing point you can achieve with ethelyne glycol (anti-freeze) is with a 70% AF, 30% water.. Any more anti-freeze and the freezing point goes up.nissangirl74 wrote: others:
- a big topic in TN was "the wintertime debate of what to run in your radiator. Some said 100% coolant, some said 50/50, some said screw it and just ran straight water". Answer why one does better than the other.
1.Oil changes is a good one, and can be very large. how many miles in between oil changes, synthetic vs conventional, switching between the two, storage effects (" I let my car sit for 8 months with the same oil, is it ok"), etc.nissangirl74 wrote:1) Oil Change Intervals - many cars can go 5,000 miles or more between changes. If you do it sooner, it's not really a benefit to the car and it's a drain on your pocketbook.
2) Stored Vehicles - we do this but we also take them for a drive
3) Rubber parts wear out with mileage. Might be good to mention weather conditions if you use this one. This is ABSOLUTELY true out here. The rubber doesn't stand up to well to our 115* summers. They will deteriorate much more rapidly here than Florida, or California.
others:
- "You should resurface your rotors every time you change the brake pads". Argue yay / nay or give examples to support different situations.
Bubba1 wrote:I was under the impression water wetter was designed to be used with distilled water, and not meant to be mixed with antifreeze. Is that wrong?
Yup. After I got forged pistons on my KA, it MUST be warmed up before I beat on it or else I'll get a round of applause from the pistons.Extreme Dimensions wrote:
I think a lot of the suggestions on this list aren't actually myths, as many are just misunderstood/misinformed statements.
For example, off the list it seems to me the op thinks that needing to warm up your car is a myth. my old block (i think....two or three blocks ago?) can verify that you do indeed need to let a car warm up before putting load on it, otherwise i would piston slap up the waazoo. So depending on your clearances,age of the motor, aluminum vs steel internals, etc etc....
Remember here we're talking about the most common case, which is going to be a stock car. Obviously if you have an engine that's modified or "built" then the rules change...krash wrote: Yup. After I got forged pistons on my KA, it MUST be warmed up before I beat on it or else I'll get a round of applause from the pistons.
Very good practice. All of us Vette drivers wont touch the throttle in naughty places if the oil temp is not proper.krash wrote:Yea for sure. I still wouldn't beat the crap out of a car thats not warmed up, but theres no need to let it sit for 10 mins just to go to the grocery store.
