tools required for front license plate holder removal? ('08 altima coupe)
General discussion area for the L32-chassis Altima
wjm3982
Car: 2008 Nissan Altima Coupe, 3.5 SE CVT, Super Black, Charcoal Leather, Premium, Tech, VDC
the plate i bought for the front of my car is cracked, and i've decided that i'm tired of having the damn thing at all and i'm gonna get me some bumper plugs (also gonna plug up the driver's side keyhole)
i did some searching on here for people who've removed it, but i didn't find anything on what tools may be necessary. i'm hoping it's a pretty simple procedure and doesn't require a flamethrower, backhoe, and/or wrecking ball
Rmuth25
Car: 08 Altima Coupe 2.5s CVT [Premium & Tech Packages]
You mean to put on the bumper plugs? You just drill out the existing holes a little bit to make them wider then you just push the plugs in!
BlackNWhite
To remove the license plate holder? You need a screwdriver.
Any of those will do.
ESP
Car: 2008 SexyBlack A/C
One of these would probably work too...but I wouldn't recommend it.
rjdmmfl1
Car: 2008 Altima Coupe, Radiant Silver, 3.5SE, Premium Package, VDC
wjm3982 wrote:the plate i bought for the front of my car is cracked, and i've decided that i'm tired of having the damn thing at all and i'm gonna get me some bumper plugs (also gonna plug up the driver's side keyhole)
well, it depends on how fancy your dealer was when they installed it... some of them have bolts with locking washers behind the plate for extra stability...
I would say some pliers (or a monkey wrench), a phillips head screw driver and a flat head screw driver should cover the bases regardless of how the dealer attached your plate holder.
I know how you feel bruh, I tool mine off as well, and used NIssan bumper plugs to fill in the holes!
wjm3982
Rmuth25 wrote:You mean to put on the bumper plugs? You just drill out the existing holes a little bit to make them wider then you just push the plugs in!
i gotta drill into the holes that are already there to put in the bumper plugs? i'm not sure i'm comfortable with that
xorcst
LMAO
Return to “4th Generation Altima Sedan (2007-2012)”
