Coolwhip »
https://forums.nicoclub.com/coolwhip-u13264.html
Wed Dec 17, 2008 9:34 am
Most of the tools offered in AIR configerations you won't want to have, such as: angle grinder, orbital sander, etc.
Your compressor will probably be on non-stop and you'll need to give it breaks to catch up to those tools on a typical at the home comrpessor.
Impact gun, air wretches are fine.
Get a huge mechanic style tool set from Sears since you like craftsmen and build off of it.
Reversable wrecheting wrenches are a must.
A habit i get into is buying the specialty tools as i need them, and buying them quality.
The others buy in sets, to save money. Having a cheap set of backups of some tools isn't a bad idea. I do so with 1/2" drive sockets since they usually go under much abuse to get huge bolts and break things loose or used on a press for a bearing or such.
Tools for Christmas is the best. haha
