tools needed for Stillen RSB install on Coupe
Marisha
Car: 2008 Altima Coupe 2.5S
Got my sway bar in and planning to do the install this weekend. Wanted to see if anyone knows/remembers what size tools are required for this. The instructions just say the following:
1. Assorted sockets and wrenches2. +,- Screwdriver3. Assorted pliers
Exactly what size sockets and wrenches will I need? The trial/error method isn't the best in my case as the tools will be in one spot (the house) and the car in another (the "shop") about 15 min away from one another (and a few cities/towns/villages/whatever they're called apart...yes, will be doing this on long island).
Grabbing all tools is not practical. Tried searching, could only find impressions threads. Any pointers in the right direction will be appreciated
adidas2go
Car: Cycle through all kinds of cars, trucks, motorcycles, and boats 🤙
Once upon a time: 1st turbo Altima Coupe
Its a 17mm and 19mm to remove the Sway bar/Endlink bolts on the ends. There are also 2 rubber grommets that hold the sway bar in the middle. You have to remove 4 bolts (2 per grommet) for the sway bar to fall free. Don't remember what size it is, but Im fairly certain its a 17mm. Just carry an adjustable wrench with you
Marisha
Got it! Thanks for the info!
adidas2go
Good luck on the install
D-Roll
Car: 08 Nissan 350Z Touring Coupe
You'll love it!
sonicbliss
Car: 2008 altima coupe 3.5 se 6MT fully loaded minus VDC
i just installed mine and i love it. what a difference this thing makes. makes me wanna throw on endlinks even more. but if you are just installing RSB, the only thing you will need a ratchet, a 6 inch extension, and a 5/8 socket. thats all i need. And maybe a pair of pliers, or vise grips. the bushing on one of the endlinks was just spinning so i had to grab them with pliers so i could finish removing the bolt. easy install tho. hope this helps.
Marisha
So yeah...the 5/8 is what I ended up having to use too when the others didn't fit...too bad I didn't see your reply until after I was done...overall very easy install and loving it
adidas2go
Really? Grrr Mehdi for putting the wrong sizes down on your writeup of the install. Now I have to go back and rewrite it
Marisha
sorry, didn't mean to add any work to your plate
here's what it looks like installed on my coupe...
in fact, that's the image that Stillen is now using
adidas2go
Welcome to the Stillen photo club
mcheddadi
Car: R8
adidas2go wrote:Really? Grrr Mehdi for putting the wrong sizes down on your writeup of the install. Now I have to go back and rewrite it
Maybe they are the wrong size lol, but that's the size I used
DarkScorpion
Car: 2008 Altima Sedan 2.5S
just curious - anyone think about changing the stock sway bar bushings to energy suspension bushings? The sway bar I put on my maxima came with energy bushings. Not sure if there would be a noticeable difference since I've never compared them to another type, but just a thought.
