took the step rails off the QXslow... a few poser pics to show!
fueler
Car: 2 Nissan's
2 BMW's
before
Took off my busted *** step rails, they were garbage!! actually they were bent so badly that they distorted all the bolt holes on the bottom of the QX4, if i bought replacement stap rails, i'd prbably only get enough bolts on to hold it there but it definitely wouldnt hold the full weight of the QX4 like the original ones did.....
maybe rock sliders in order??? hmmm
definitely gave me some ground clearance though!
xmas present
stock step rails didnt protect as well as i thought they did uncovered some dings!
i can now see my lower control arms!! which are about to get some poly bushings (the stock bushings are cracked so bad that i can see the damage even with the control arm installed
cant wait to ride steady on the freeway again! These cracked stock bushings SUCK!!!
PS the stock step rails weigh close to 40 lbs EACH SIDE!!! 80 lbs weight reduction, thats nice!
Modified by fueler at 1:16 PM 1/2/2009
Modified by fueler at 9:30 PM 1/3/2009
Modified by fueler at 9:32 PM 1/3/2009
screwinitupagain
Car: 1997 Nissan Pathfinder SE
Its about damn time Adam. Now you are starting to look like one of the big-boys. In all seriousness I always like the look better without the steprails.
fueler
Car: 2 Nissan's
2 BMW's
thanks boston. now if only it was lifted on bigger tires.... but im all about reliability and i dont want to deal with broken CV's in Baja (although being stuck due to no ground clearance, is just as bad if not worse)
screwinitupagain
I say keep the same size tires but lift it & get some sliders. CVs are that bad, hell I've replaced them out on trails before. Just keep one or two extra in the back end & you'll be set.
AJRK
Car: 2001 QX4 4x4, 2003 Jaguar XJR, 2014 Cadillac ATS 2.0T 6MT
Looks pretty good Fueler.... and I have the same valve caps as you
InfinQX4
Car: 2000 QX4
Thanks for the pics - I've been working on thinking about pulling mine down and was curious on what it'd look like. Looks good, espically in black! Post some more when you put on whatever is going to replace them.
SnowSurfLax
Car: 1999.5 Infiniti QX4
2006 Infiniti M35 Sport
Nice! Now I'm definitely taking mine off. Just waiting for the wife to be done being pregnant (she needs to be able to get in and out easily).
For more clearance, you need Nissandoms SFD. It's dirt cheap as far as lifts go. And you can get the AC lift for extra clearance... I'd do it if I was allowed to spend that kind of money right now.
And now that I've seen the split bushings in a better pic, I'll be doing those as well. I've got the death sway developing. Still early, but in 6 months my *** end is going to be wagging more than happy dog's.
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
Did you get a big clunk on acceleration with the shot bushings? I did, butnever had a freeway sway problem.
Expect a major battle getting the nuts off the bolts. None of them would comeoff by hand, even with a 24" breaker bar. Ingorsol-Rand'sbaddest 1/2" impact wrench got three out of four after some work, one hadto be cut off with a pneumatic cut-off tool. The FSM specs replacing the bolts and nuts, I can see why. Note that the front and rear bots are slightly different lengths and different p/ns.
Folks going with new stock bushings: You do NOT have to buy a whole newtrailing arm. The stock bushings are available separately, the local garage charged me $20 an arm to press them in.
bmlawless
Car: 1999 Infinity QX4
First the tow hitch plug, now I have to buy valve stem covers. Will this customizing never end? :b
I need my time for the body and suspension lifts, tilt wheel, armor, disc brakes, body armor, bumpers, lights, and interior upgrades on my Jeep.
Lars
Car: 1998 Pathfinder 5spd
I just ordered the split bushings a few days ago. When are you going to do them? Post up some pix if you can. I'll be doing mine in a few weeks. I don't have the death sway yet, but when I loaded an 1/8 cord of wood in the back of the Pathy it swayed like a cheap hooker.
screwinitupagain
You really have to take 'em to a shop that has a press. I tried doing my own last year & couldn't & finally took 'em to a friend of mine that owns his own shop & he did 'em for me.
Chuck Tribolet
'87 Chevy Corvette
The shop needs both a press and the right stuff to do the pressing. The armneeds to be supported on somthing that has a hole just bigger than the ODof the bushing, the bushing needs to be pressed out with something that hasan OD just bigger than the iD of the arm.
screwinitupagain
I love the poly bushings, plus they'll outlast my Pathy
pathfinder9035
Car: 2001 Nissan pathfinder
hmmm...maybe i should do that.. what do u think guys..should i take those off too.
by the way fueler...your q now looks sexier and more meaner!
fueler
Car: 2 Nissan's
2 BMW's
Chuck Tribolet wrote:The FSM specs replacing the bolts and nuts, I can see why. Note that the front and rear bots are slightly different lengths and different p/ns.
Thank you for posting this. I will make sure to have the bolts before tackling this job.
fukinitupagain wrote:You really have to take 'em to a shop that has a press. I tried doing my own last year & couldn't & finally took 'em to a friend of mine that owns his own shop & he did 'em for me.
Are you talking about removing the stock bushings, or pressing in the new ones? If pressing, did you have to press the split ones??? Or did you purchase the blue non-split ones? I was hoping they'd just pop right in, as soon as I get the stock bushings out.
screwinitupagain
Hell take 'em off! I haven't rocked the step rails in like 2 or 3 years now.
screwinitupagain
I'm talking about pressing the new ones in. The old ones are a pain in the farkin arse to pop out though. I have the red/pink split bushings.
And just for funzzies heres a pic from about 2 years ago with no lift, no ugly step-rails & 31's
fueler
Car: 2 Nissan's
2 BMW's
those BFG M/T tires look mean just like that. Do you remember how wide they were??
fueler
Car: 2 Nissan's
2 BMW's
pathfinder9035 wrote:hmmm...maybe i should do that.. what do u think guys..should i take those off too.[
I'd leave em the way they are. i think they'd look cool with a lift on and bigger tires!
pathfinder9035
well i do have bigger tires on... the ones on my pathfinder are almost 31's...its 30.5 inches. OR 245 75 16. really enhances the look!
Chuck Tribolet
'87 Chevy Corvette
fueler wrote:Are you talking about removing the stock bushings, or pressing in the new ones? If pressing, did you have to press the split ones???[/url]
I was talking about the pressing the old stock bushings out, and pressing newstock bushings in. The stock bushings lasted me 140,000 miles, and thisis a working street truck (tows my boat).
I think the cause of the bushings going away is the rear bump stops disintegrating and allowing more rear alxle travel.
screwinitupagain
fueler wrote:those BFG M/T tires look mean just like that. Do you remember how wide they were??
Yep those are 31x10.5 BFG Mudterrains on 15x8 steel black rockcrawlers with 3.67" of BS. Excellent tires & after I put my lift on & those tires ran the course of their life I got the same tire only bigger (32's)
carnal_c30
Car: 2001 QX4 4WD
2002 QX4 4WD
1999 Q45 VIP life
1996 I30 5spd
1998 I30 Auto
1997 Maxima 5spd Supercharged
1995 240SX S14.5
1995 240SX S14
1994 Hardbody KC V6 5spd 4WD
1972 BMW 2002
1972 BMW E9
damn it does look good I hate the stock running boards because all they do is get the back of my jeans dirty when I'm hopping out because the qx4 isn't high enough to even try to use them. It may take something away from the 'luxury' look
Qxxx4
2012 Ford Mustang
wasnt there a pic of a wide view of the whole q? i wanna see what it looks like again. im considering taking mine off.
Get this im even considering getting big tires like the big boys here. Wouldnt need to switch winter tires and wouldnt be afraid of curb rash, and i can get my tires to stick out the sides (SWEET) and if i do find some places to off road..i can do it.
"bling" wheels are too expensive, seeing fuelers pics i just noticed their 16" wheels...i think id get more bang for my buck and practicality than chrome blings. and id feel manlier.
Qxxx4
2012 Ford Mustang
nvm...the pic loaded...and i like it.....
thanks fueler!
and fukinitupagain...i love your pathy. its MEAN lookin
screwinitupagain
Thanx but its gonna be even nastier than it is now here in about 3 or so months (when I can get everything I wanna get done, done) but besides the looks its a f*ckin mule offroading! I'll never be able to do any professional rock crawling with it but I can run most any trails like URE & Coal Creek & places like that (although I wanna hit up Moab & Baja). Plus thats an old pic thats pre-lift & Herciliner & 32's, etc.
fueler
Car: 2 Nissan's
2 BMW's
i like being able to offroad all i want.... then just wipe off the rims and bling bling through the city..... even better, polish them with some wax and watch as the panties drop ( i wish... cant really stunt in a 99 anymore )
screwinitupagain
Yeah, well I like wheeling the hell outta the R50 & then rolling through the city with mud & sh*t & watching the ladies run away in fear!
Qxxx4
2012 Ford Mustang
question...that big bar in the 5th pic...what is that? mines kinda bent...is that bad?
