Took the plunge to synthetic oil early.
Nissan 350z / Nissan 370z general community discussion forum
PalmerWMD
Car: 2004 350Z
My first oil change was at 1000 miles ( break in with 5w-30 bulk Dina oil).
My next change was at 2500 miles figuring to get rid of the last break -in residuals that may be in the crank case.Also I was getting increeasingly nervous about running my engine on 5w-30 dino juice as much as I like to rev it.
What to refill was the question?
Well, I felt my 2 perennial favorites of oil for NA engines, Mobil1 0w-40 and german castrol 0w30 (runs thick at operating tempos for a 30 weight),Might be tooo thick at operatings temps for this real new and tight engine.
usually I like thicker oils for the HT/HS, but I went with Mobil1 10w-30 which is about nine and a half centistokes at 100 degree C, if memory serves.
Also M1 is VII's free in the 10w-30,but not in the 0w-30 or 5w-30 versions.Even tho winter is coming up , living in kentucky the 10w-30 will be plenty start-up capable and the 5w and 0w- will be unneccessary.
So now I am enjoying VII free, Mobil 1 10w-30, Yayy!..
As hard as this car was driven lately, I felt a change was neccessary, also it gives me piece of mind to have a group IV oil in my brand new VQ35.
I know your not supposed to switch to syn early says conventional wisdom, which is usually a good starting point.For this reason I didnt put in syn on my first change.
But many other highly modern engines have M1 as factory fill.So how harmful can an early syn switch be?
Amnyway i did it and feel good about it.
Fred..
Altiman94
Car: 1989 Nissan 240SX
I'm sure all will be well. How you likin it so far?
PalmerWMD
Car: 2004 350Z
Loving it.Its Awesome!My best car purchase ever?
Fred..
Altiman94
on a side note, do you think 5w-30 mobil 1 is ok for the cougar in the winter? If not, what would you recommend. I woudl liek to keep it on synthetic, but if there is something you think would be better, I'm willing to try. The 240 is in storage until i can finish the de swap and turbo.
PalmerWMD
Car: 2004 350Z
It might be a bit over kill for a looser motor ( V8 Cougar?)
Also for higehr mile engines I thinka good bet for you is 5w-40 SynPower , really like its aditive package too almost a drive-clean type oil.
Fred..
Altiman94
cougar is a 2.5L v6 with 32.5k on it. what do you recommend?
PalmerWMD
Car: 2004 350Z
Altiman94 wrote:cougar is a 2.5L v6 with 32.5k on it. what do you recommend?
Chevron Supreme 10w-30, Valvoline Durablend 10w-30, Pennzoil 10w-30
Fred..
Altiman94
sounds good. thanx fred
MOTOP
Car: 04 G35 sedan
Fred,
Good call. Might I also suggest changing diff and transmission fluids after 3k miles? I should have done it that early on my G. Mileage went up by about 2mpg.
PalmerWMD
Car: 2004 350Z
MOTOP wrote:Fred,
I did that but not until 11,000 miles.. , still much earlier than recommended.
My transmission shifted so much better afterwards (see other posts here in this forum)
Fred..
Return to “350z / 370z Discussion”
