took my car for the first test run - problems
timmyk
Car: s14 96 240sx and 89 s13 240sx
went for a test and run and had some problems...perhaps someone could explain what is going on and why its not working...
ka24de-t 96 with conversion s13 harness for enthalpy rs tune480cc injectorsz32 mafz31 turbo t3
now i had this same setup except a cheap ebay turbo before and it is was running fine! [until the cheap ebay turbo blew up cause of no oil restrictor and no coolant lines] [now i have both to the z31 turbo]
anyways took it for the first test run with the new setup, and i wouldnt go into boost or even over 10 vac? yet i can rev it up as much as i want and it wont die at idle, anyone know whats going on here? what to check, whats the problem?
things changed since previous setup:relocated z32 maf to blowthruinstalled smaller turbo and new downpipeadded coolant lines from tb to turbo
1mansho
its very possible that you may have a boost leak might want to get that check or clean your maf?
