i made a dog out of my buddies rods and crankshaft. its pretty sweet.eddiec wrote:makes a nice paperweight.
or maybe some ricer would give you some cash and turn it into a rear view mirror ornament.
LOL yup! Damn, its a good thing you took those out when you did. I'm sure it only would have taken a few more runs of boosting before that rod let go and wrecked your entire motor. ...And yet the ringlands are perfectly fine! Odd huh, It was always the assumption that the ringlands would go, then the rods-- but here we are again with the rods proving to be the weaker part. Interesting. I wonder if down the road we're going to start seeing pauter rods/stock piston combos hahaCraving4Boost wrote:lol...apprently not for 20psi (right fiznat? haha jk)
so you think i didnt have enough oil or something? what do you mean by excessive clearences? trying to make sure i dont make the same mistake..nissanfanatic wrote:I think it was a lubrication problem and/or excessive clearances that lead to the piston wedging inside the bore and bending the rod. Cylinder pressures alone could NOT have done that...
Just look at the direction by which it bent. That is mechanically wrong for the rod to fail in that manner. It had no other choice. Cylinder pressures would have made it bend in a perpendicular manner, AKA it would have bent the way it looks easiest to bend.
yes they are in order...and yes #4 is slightly bentnismofly wrote:are those lined up in order? if so is it just me or does your #4 have a very slight bend to it as well?
