took apart a kade
nismojunkie
i finaly got done taking apart a kade and i wanted to know the best way to clean the oil and crap off the parts. my dad told me kerosene woudl work fine, is there any better ways to do it?
Scott McLellan
Go to the drive thru car wash. You can also buy a set of engine cleaning brushes from summit racing or jcwhitney or something that will clean out the passages better. For chemicals to use, try some parts store degreaser that comes as a concentrate. Apply that stuff liberaly and let it soak a little and then blast it with soapy water. If possible, hot water will work better. If you wanted to, you could hook up a garden hose to your clothes washer hot water spicket if it's like ours and stick it out a window to where you'd do it (I know my mom wouldn't like this but)
nismojunkie
i might actualy try the clothes washer idea, thanks
absolute
Car: racing,drawing,raping,games,girls
simple green for the engine cleaner its the best, we used it at carmax when i detailed there
nismojunkie
where do you get it at?
deviousKA
Car: 90 240sx NA /72 Datsun 510 NA /86 corolla GTS NA
Use a couple gallons of gasoline in a tub, with some rubber gloves on and some brushes.
dubstyles240
deviousKA wrote:Use a couple gallons of gasoline in a tub, with some rubber gloves on and some brushes.
thats the worst idea i've ever heard. unless you mean like a keg tub, outside. But if you meant bath tub... shudder...
Gasoline is a little more potent than simple green too... not safe to work around for long periods of time.
nismojunkie
ill try the simple green stuff, i tried to pressure wash the block yesterday, but the starter cord on 1 pressure washer broke and i couldnt find a hose for the other one.
