Ghettokracker71 wrote:I'll agree with the helical vote...Just gotta find how you could get one in there...
Turbocharged applications usually make alot of power therefore result in wheelspin;This is a fact of life unless your car has a "subaru" badge on it. I agree that springs,struts,LSD, better engine mounts, bushings and etc. will be a big help. Some sticky tires and pratice timed launches until you find the fastest launch possible (minamal wheelspin@maximum RPM/boost).
I would LOVE to have a KA-T Altima,good luck!
theres talk of swapping the ATTESSA AWD system into a stanza since the U12 Bluebird had it, but so far it's just hearsay and it'd be a lot of fab work on the rear end.
basically i think ill look for an lsd and lower it, that should help with wheelspin when my HPs around 200-250, which is what im aiming for right now.
first things first, i need to do a 5 speed swap and then start collecting parts for the turbo setup.
