TOO MUCH OIL?...or a rod bearing issue?
jrsink
yeaterday i was driving my vert in brandonit began to overheat at a light
i already had new water pump, timing belt, and head gasket donecoolant level was perfect, oil level was just under full mark on the dipstikSOi added a full container of oil stabilizer (about a half quart) to the motor.
about an hour later i started hearing some tapping noises like the valves/valve tap/lack of oil
10 minutes later...i was just trying to get it home, the tapping had turning to full rattling and it was begining to lack seroius power and soon enouhh i was on the side of the road...
WTFi still need to check the gear oil level since the tow truck guy just dropped it off but i sounds like a bottom emd broken rod or something.but if a rod broke wouldnt it sound much different running on only 3 cylinders, bc it didnt sound differnet, just had no power to drive away. rpm would only get up to about 2500 or 3000 before almost dying...
Florida240sx
First check your compression. What does your oil look like?? Drain it and see if any chunks or shavings of metal. If nothign is found then it could be a manifold leak, MAFS, injectors went bad etc.
