TOO MUCH OIL!!! I NEED HELP!!!
skiski329
Car: Nissan Altima Coupe 3.5
i have a 3.5 altima coupe can any body tell me how much oil i need to put in? they said at the dealer 5.5Q. any body know how i can fix this problem? or it it ok that my oil level is above the max line?
shift_mikey
Car: 2008 Altima 3.5SE Coupe w/CVT
the 3.5 take 5 quarts of oil with a new filter.
Half a quart over isn't the end of the world, but it might be a good idea to pull the drain plug for a second and put it right back in. gonna be messy, you decide how important it is to you LOL
skiski329
pulling the drain plug will be easy but to put it back it is the problem. LOL well thank you for telling me that it is only 5q. unless some one tells me that it will cause sever damage to my car i think i will leave it till my next oil change. but THX
adidas2go
Car: Cycle through all kinds of cars, trucks, motorcycles, and boats 🤙
Once upon a time: 1st turbo Altima Coupe
pulling the filter will also drain about half a quart. just a thought.
SHIFT_2.5S
Car: 2008 Nissan Altima Coupe S 2.5
I think it's 4.7 quarts for the 2.5S, with new filter.
johnny_d
Car: 2008 Altima Coupe V6 SE w/ CVT
i remember the manual said 4 and 7/8 quarts so just about 5. Just undo the drain plug when it's about to squirt out use ur hand to turn slowly when enough came out then just plug it back..... will be messy but hey
wild willy
Car: 02 Altima SE, 91 MR2, 04 Odyssey
skiski329 wrote:i have a 3.5 altima coupe can any body tell me how much oil i need to put in? they said at the dealer 5.5Q. any body know how i can fix this problem? or it it ok that my oil level is above the max line?
Who put too much oil in it in the first place??
That little book in your glove box........Open it up
all4sho
Car: LOTS of Nissan's
it only takes 5 qts and a nissan #15208-65F0C filter
skiski329
i put it in but they told be at the dealer to put in that much
adidas2go
stealership strikes again
wild willy
adidas2go wrote:stealership strikes again
Rule number one...Never listen to a dealer.....
SHIFT_2.5S
skiski329
i pulled the drain plug and got it fixed. but that was the longest oil change ever. and when i was done i felt some thing wet! there was oil dripping out of my sweat shirt!!!. LOL that sucked. (it was also snowing and -2 outside)
