Too Much Fuel???
anthonysr07
Car: 1990 240sx
I have the s13 blacktop swap in my 90 240sx, and its like i am getting too much fuel. It always smells like gas, and my gas mileage sucks! Also, it will be running good and fast, the out of nowhere it will lose power. I feel like i am driving a bone stock escort! Then all of a sudden, power is back and i am quick again. Any ideas??
onosqv
Car: '92 240sx Vert
stock sr20? what modifications have you done to it?
pulled the spark plugs to see if you are running rich?
check injectors & injector insulators?
check for leaks?
has this always happened? just started happening after some modification?
is timing set correctly?
etc. etc. etc.
anthonysr07
Car: 1990 240sx
its got a front mount intercooler and a blitz BOV. Thats it. I know i am running way rich due to the smell of gas. Its always ran rich. I have to pull the injectors to see if there are any o-rings missing etc.. No boost leaks, already looked for that (my first guess). Tomorrow i am going to pull the plugs and take a look. I will keep you posted. Its like i put the gas to the floor and turbo spins like an m-fer, but no power to the wheels. Dam troubleshooting.
anthonysr07
Car: 1990 240sx
Update.... Spark plugs good, injectors good, vaccum lines good, fuel lines good. The only thing thats a little messed up is the 1st injector clip, part of the plastic guard between the 2 wires is broke, but still seperates connectors. Another thing... crank angle sensor has 2 wires that are a little bare right under the clip. Is that enough to mess anything up?
L_adan_C
Car: 92 240sx/ Hatch/ red
not sure if those 2 crank wires would throw off your air/fuel ratio, but you might as well repair the wires. Not sure how much this would help you, but check your fuel filter. Hell not sure how much help i've been, keep us updated if you find anything. Any codes?
RunCool
Have you checked your fpr?
anthonysr07
Car: 1990 240sx
fpr? i dont know what that stands for. this is such a weird problem. Im starting to think maybe my maf sensor is bad. i hear a lot of 240 owners having that problem. let me know what the fpr is.
nuts510
Car: sr20det 95 240sx, rb20det 93 240sx convertible, 78 280z turbo, 71 ca18det datsun 510, 72 scout,88 CR
check your fuel pressure, when the fuel pressure regulator goes bad your fuel pressure or grow up to about 60 psi or more this will make the car run poor and destroy your gas mileage. also check the temp sender located on the water housing inlet they can get corroded and make poor connection. Also the air flow meter and wiring can destroy your gas mileage. I hope this helps
anthonysr07
Car: 1990 240sx
How can i check my fuel pressure and check my regulator? i know the maf wires are good because me and my buddy made it.
onosqv
Car: '92 240sx Vert
ummm... search, maybe?
For regulator, find the factory service manual (FSM) available for free d/l on this forum. There are test procedures in there.
To check your fuel pressure, you need a fuel pressure gauge... you can search for that also...
anthonysr07
Car: 1990 240sx
thanks. i will keep everyone posted
anthonysr07
Car: 1990 240sx
turns out it must have been my wastegate actuator. now i have 0 boost even at wot. i moved the rod and no pressue built up.
