myRed240 »
https://forums.nicoclub.com/myred240-u4220.html
Thu Dec 07, 2006 7:45 am
I tried to start my car the other day and all I got was sputtering and fuel spitting out of the exhaust side of turbo. I pulled the plugs and they were soaked in gas. Tried several times to no avail.
Went back to inspect the injectors, so I pulled the fuel pump fuse, removed gas cap and then cranked it to relieve fuel pressure. To my amazement it fired up. It ran like crap but it stayed on. I turned it off, replaced the fuse and tried to crank it up, but it wouldn't-same symptoms as before. Removed the fuse again and it started again. WTF?
I know that it's getting fuel, in fact I believe it's getting too much.I've inspected the injectors and the O-rings look good as new.
Here's what I've added to my car:
NGK BKR7E plugs (at first gapped to .033, now at .042)Z32 fuel filterEnthalpy ECU tuned for:New Walbro 255 fuel pumpNew DW 555cc injectorsZ32 MAF
This is all on a 95 240sx with original motor (27k miles) that ran like a champ before this. The car has not seen boost yet....
Thanks for any help.
