Honestly, being an audio guy I hardly think the TE601D is pulling that much juice to cause a problem. Before upgrading an alternator, I'd first look into a few things. How is your amp ground? Remember your ground is actually the amp's "input" for power the the big power wire is the "Return" wire to the battery. If you have a bad ground, it could cause a whole bunch of issues.
The next thing I would suggest is doing the big 3 upgrade. Here's a good how-to that explains it in more detail.
http://knowledge.sonicelectronix.com/ca ... grade.html
It makes a big improvement. I have it done on my lancer, and run ~2000 watts RMS on my stock 120 amp alternator. I hardly see dimming in that thing. When I upgrade the Rogue's audio I'll be sure to the big 3 as well.
