dash »
https://forums.nicoclub.com/dash-u40408.html
Sat Oct 10, 2009 1:48 am
you won't see 1/10th of a hp gain on a dyno, or 1/10 of a second lower et, with a light flywheel....for whatever that item is worth to you Sure it affects the way a motor free revs, which mean nothing. You can only accelerate in gear under load.Our starion oe flywheel weighs 36 pounds. 11 pound alum unit... zero difference in perf.Under 'lab' conditions, I suppose one could prove how a 25# lighter vehicle improved
I'd only buy one of those XTD clutch/flywheel packages, for the good value,and the convenience during installation. Weight reduction of the lighter flywheel(=lighter car), being the primary interest. After all, that is whole idea behind putting the CA18 in a corolla
