float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Wed Sep 24, 2003 7:52 am
Even though you fixed the problem, I'm going to reccomend this incase anyone else reads this on down the road. I had the same prolem once and it was due to the thermostat being stuck OPEN, (which never happens). I simply changed the thermostat and it fixed the problem. Also, you don't want the car to run too cold because the timing is retarded and the fuel mixture is richened.
