this sounds very cool.. i'd love to go with amber to match the dash lights, mood light, and my homelink mirror.but i read that it might not look right with the standard map light white lens cover.cdmuile wrote:I did the same. Went with the blue. Very satisfied. My interior is black leather and the blue tint is way cool!
The white I have are true white as all LEDs are so with a blueish tint in it.Or, as others have suggested, the amber ones will match the dash lights.orijin wrote:what do you guys think the color i should get if my interior is cloth gray?
The LEDs are a strict replacement of the halogen bulbs: Remove and replace and check that they are working (they are sensible polarity wise so you may need to turn them 180 deg to make them work). Can an english speaking person rephrase that to be more understandable?orijin wrote:And also do i need anything else besides the bulbs if i were to buy the led reverse lights? Are the bulbs pretty much plug and play?
The DE1375 is equivalent to 31mm festoon bulb. Different vendors uses different terminologies but they are interchangeable. The 31mm festoon is for the dome light alone. The map light is different size. I bought 3 x 31mm festoon bulbs but found out later that the map lights are different than the dome lights. Now I got 2 spare 31mm festoon bulbs (any takers?).orijin wrote:i dont really want to buy the leds from the ebay person as theres a website that offer the leds at lower prices and offer a variety of choices such as 12 led versions and all my friends buy their lights from superbrightleds.com
According to Svlvania.com link below http://www.sylvania.com/Consum...Guide/
It says for our rogue the map, dome and trunk light all uses a DE3175 while the glove box uses a 158 bulb. So i don't know
Kot says its the festoon 31mm ones so does that mean they're 31mm ones for the map, dome and trunk?
Im probably going to try to change the dome,map,trunk,glove, the whole rear combination lights and license plate lights(hopefully it can look like the lexus is250 lights)
Another thing i just want to switch out the halogen bulbs out for a set of white halogen bulbs (getting a pair for free) anyone have a how to guide on how to take out the bulbs. I was in my garage yesterday looking at it and it seems you need to take out some things to be able to replace the bulbs just not too sure what they are. This is my first car ever so i have no idea what to do on these things.
Superbrightleds.com have good prices, but not for everything, shop around.orijin wrote:i dont really want to buy the leds from the ebay person as theres a website that offer the leds at lower prices and offer a variety of choices such as 12 led versions and all my friends buy their lights from superbrightleds.com
From what I recall, there are all 168 bulbs (short ones). I will check for you tonight if you are not in a hurry (took some pictures too).orijin wrote:According to Svlvania.com link below http://www.sylvania.com/Consum...Guide/
That is what I am doing right now. I have to send some LEDs back at superbrightleds.com as they are not satisfactory for the rear lights.I will order the rear lights and turn lights (front and rear) at vleds.com soon, so once again, if you want me to be your penny pig, I will be give feedback soon.orijin wrote:Im probably going to try to change the dome,map,trunk,glove, the whole rear combination lights and license plate lights(hopefully it can look like the lexus is250 lights)
On the passenger side, it is quite easy to access the lights (turn 1/4 the light to remove it and then disconnect the wire. To install it, it is easier to install the bulb and then connect the wire).On the driver side, remove the air intake (3 plastic hardware in the front and it is clipped at the rear) you will have then plenty of place to do it.orijin wrote:Another thing i just want to switch out the halogen bulbs out for a set of white halogen bulbs (getting a pair for free) anyone have a how to guide on how to take out the bulbs. I was in my garage yesterday looking at it and it seems you need to take out some things to be able to replace the bulbs just not too sure what they are. This is my first car ever so i have no idea what to do on these things.
Modified by orijin at 11:04 PM 7/28/2008Pescakl1 wrote:Here is a picture of the halogen bulbs: The ones on the left are for the Map, the other ones for the Dome and the Trunk.
