Dori Dori »
https://forums.nicoclub.com/dori-dori-u2872.html
Mon Mar 17, 2003 10:28 pm
Cyberkreig, are you talking about this:Quote »From Jun Japan[CAUTION]Apply a solid type cam shaft.The head that has lash killer process is required to change the automotive valve system for RNN14 (separate product ; valve INT/EXH, locker-arm, pivot, locker-guide, locker shaft retainer, locker valve spring, and shim. )[/quote]If so, they are talking about the Pulsar SR20DET (RNN14 is the Pulsar GTi-R chassis code).
If not, where did you see that?
