Tomei Procams, BC valve springs, stock headgasket and clearance
S14toRPS13
I have Tomei Procams 260/260, BC valve springs and plan on using the stock headgasket. My concern is the piston to valve clearance. Any of you guys run a similar set up? Will this be safe. Maybe I'm just paranoid because I've seen one too many times of pistons hitting a valve. So I just want to know if I'll have enough clearance running these cams while still using the stock hg.
240_SeX
Car: 1992 240SX SE
The only way the piston will hit the valve is if the valve timing is off. however i would suggest a headgasket anyway, its cheap insurance and your halfway there just putting the cams in.
