http://www.livermoreperformanc....htmlKamin wrote:what about using an accusump system guys?
You sure it is not the rear one you want to block? I know for a fact the rear on the RB26 is blocked.krayton wrote:http://www.skylinesaustralia.c...&st=0
so they say block the front one, and put the restrictor in the rear.
but for the circuit races they also suggest a bit more....
looks like a lot of work. still trying to find more info
i think they are referring to the NA rb25. since i believe some of those guys were using those with a rb30 build upDarius wrote:My question about that table was which RB25 are they referring to that doesn't have VVT? I thought all RB25DET's had VVT?
which is an excelent idea incase you ever need to remove them, allen key plug is much easier to remove than one with smooth face and is pressed in...themadscientist wrote:When I block passages I tap the hole and thread in pipe plugs. A friction fit cylinder of metal should be adequate though.
