mikecef2 »
https://forums.nicoclub.com/mikecef2-u67950.html
Sat May 08, 2010 3:17 pm
I posted up a little while ago the issues I had with my lower trans harness not causing my starter to engage because of my 5 speed swap. So now I found my issues with the park neutral switch and now it cranks perfectly but my ECU isn't providing the ground circuit for any of the outputs i.e. relays, injectors, coilpacks. Has anyone had this problem? I have a Tomei #62 ECU. I don't have it mounted in the stock location (its laying on the carpet) and I'm not sure I have the block grounded to chassis. Can these cause the ECU to not provide a ground circuit? I appreciate everyones input!
