Tomei Diff fluid
nismos13silvia
Does anyone know if I can just use regular differential fluid from your local NAPA or do I need specific Tomei Diff fluids??
Modified by nismos13silvia at 9:20 PM 4/4/2009
wynnEZ
Car: 90 240 CA POWA!
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
why do you need tomei diff fluid? i run 80-90 non synthetic in my r200 diff (smae thing you have) i have a kaaz 1.5 way, the only other thing i have to do is add the stupid lsd additive bc of it, vlsd dont require the additive
nismos13silvia
I don't need it I'm asking you guys "do" I need specific Tomei diff fluids. My bro said I should be ok with diff fluids since it's just my DD but I don't want to throw away $900...He said I might have to add additives...
Modified by nismos13silvia at 1:50 AM 4/5/2009
ZOMG.SR20
Car: 1990 s13
you need the additive.
n240sxfnatic
redline 75w90
sayin608
Car: 91 RpS13
where can I find some redline 75w90 or Motul??
KFL
Car: S14
Off memory you should run non-synthetic for tomei/kaaz, nismo can take synthetic though.
sayin608
Car: 91 RpS13
where can I get the additives....can I got to my local NAPA??
MastaYu
Car: 92 Nissan 240SX SE HB
you need a friction modifier, if your going with regular gear oil.
maj Andres
Car: Zenki, '95 Model, w/ S14SR20DET
sayin608 wrote:where can I get the additives....can I got to my local NAPA??
Okay. For one, wynnEZ just posted the link! And two, why don't you try calling your local NAPA, or heck why not check the website? Come on guy.
Salem240
Car: '05 Pathfinder 4X4 SE
'98 240SX SE
Yes.. it's called friction modifier (it gives the oil friction for the clutch plates in the diff). Or you can surf on the internet and find some Motul 90PA LSD oil that has the modifier already in it I ended up paying about $27 to have a 2litre bottle shipped to my door. And its mineral based so its the exact same stuff that KAZZ, Tomei, and Cusco sells for their clutch type diffs but for less than half the cost.
sayin608
Car: 91 RpS13
easy bro....I'm not a true gear head....just getting into this stuff....just asking that's all....my bad for missing the link......thanks to the rest...
Modified by sayin608 at 9:27 PM 4/24/2009
