Post by knightrider » https://forums.nicoclub.com/knightrider-u3208.html Tue Aug 01, 2006 7:23 pm
Post by c-rad » https://forums.nicoclub.com/c-rad-u19918.html Tue Aug 01, 2006 7:38 pm
I'm pretty sure Tomei and the other big name companies use a type of scramble board so you can't rip off their tunes. Otherwise they would be floating all over the internet.knightrider wrote:you could try contacting tomei, they should be able to answer your question. i think the only other way would be to put the chip into a programmer and read the bin, then you would be able to compare it to a stock map and maybe figure out what maf and injectors its setup for.
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
