r34 gtr wrote:the intake cam on the turbo CA is a little lower lift than the exhaust cam, right? i cant remember but i seem to remember 248/7.8 for the intake and 248/8.5 for the exhaust. just wondering (and dont by any means mean to thread jack). might help with the final decision. ive got a questionable intake cam in my engine and it has definitely affected the idle and torque curve. duration and lift? wish i knew.
FAQ FTW Tim; IN 240° @ 7.8mmEX 248° @ 8.5mm
dattodude wrote:...Interesting reading, but I doubt that with the precision at which a cam is ground, that only the poncams are ground to 0 degrees. This is explicitly said for the poncams, which are the 'user-install' cams of the tomei range. But this not being said for the procams makes it an assumption either way....
I don't think they're saying that the Poncams are ground @ 0°. I think they're saying that they adjust the paired cams to have the optimal overlap with out the use of cam gears. Now what they have decided is "optimal" is probably geared twords good mid range, with decent top end, and mild loss in bottom end.
I think the Procams don't really have that taken into account as they assume that if you are going to purchase cams with 260/270° of duration (a considerable amount over stock), that you are building a powerful enough motor that you will be running cam gears and will be tuning the cams to your specific needs.
To index the cams (pre-set the overlap w/o the need of adjustable cam gears) they have to actually modify the placement of the dowl pin and bolt holes on the end of the cam. To figure out the best index, they would have had to ground a set of cams at 0°, put them on a CA w/cam gears, dyno the motor multiple times to find the optimal cam timing, and then grind all of the retail sets with the dowl pin and bolt holes moved to put this indexing in place already.
That's a lot of work and I don't think they would do that for what they would consider a "race" cam that you're probably going to put cam gears on and index anyway.
davidricardo86 wrote:...Kouks & Ryan, what are you guys using and what do you think of your current setup? From experience, what would you change? What would you leave alone?
...I was also planning on using the Tomei uprated springs to go with the new cams. Im worried about valve float too. If i used stiffer springs, wouldnt there be a greater chance of floating if i used the oem valves (instead of lighter material valves)? Or i can obviously keep it to a safe limit and not go past xxxxrpm and be fine. From all the info ive read on the CA, i read somewhere that 7-8k rpm is safe on factory valvetrain, it just doesnt produce anymore power. I appologize if it seems like im not understanding this but the fact is thats it isnt so easy, plus its a lot of money and time spent.
I'm on stock cams right now, but I do plan on changing them. I kinda wish Dee was around right now to chime in as he's played with A LOT of different cam setups.
As for the stock springs, it depends on the cams that you end up using. I think the general concensus is that on the 256° and 260° cams you're fine with stock springs as long as the lift stays below 8.8mm.
As far as the actual valves are concerned, don't worry about it. They're fine for just about any power level.
The valvetrain in stock form is generally agreed to be good to 8K w/o problems. The only reason it doesn't make power up that high is because of the cams.
8K RPM is FAST. I know that Honda has got a 10K RPM redline on the old S2K's, but that is a 5yr old motor w/VTEC. Remember that even though this is an exceptional motor, it's still 20+year old technology. You can build a 10K RPM redline CA and have it make great power, but it won't be streetable.
ks13 wrote:but wouldnt all camshafts be setup to work with each other?
A matching set of 256's, paired with adjustable cam gears, would not see any benefit in being able to advance/retard ignition timin? s15 t28, .020 bigger pistons, z32 maf, power fc etc.
Modified by ks13 at 8:41 AM 12/3/2006
Were not talking about ignition timing. We're talking about cam timing, or "indexing" as I like to call it as it helps to reduce confusion. This is the actual timing of when the intake and exhaust cams open in relation to eachother and the crankshaft.
Indexing helps to decide where the motor will make power with a given set of cams.
