Tomei cams
flatrate
Car: S14 kouki
where does the head get machined to compensate for the additinal lift?
julio
Car: RB26 AWD converted S14
flatrate wrote:where does the head get machined to compensate for the additinal lift?
flatrate
Car: S14 kouki
i assume it gets machined out where the cam lobe "swings" so to speak...
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Yep. There's a picture somewhere in the RB forum of NICO that shows someone's work on the cam lobe relief grooves to accommodate a high lift cam. They pretty much just took a carbide bit to the edge and knocked it down until the cam cleared it. Nothing really scientific about it except you can't cut it below the "ring" on the hydraulic lifters or they won't pressurize and you'll have problems. I am not sure how much material must be removed but if you absolute cannot avoid cutting the reliefs down below that ring on the hydraulic lifters, you'll need to consider switching to a shimmed solid lifter valve train and cams for solid lifters. Now you're talking big-boy money! :biggrin:
flatrate
Car: S14 kouki
really wish i would have modded the head before it was installed now damit
Darius
Don't worry. Plenty of power can be put through the stock head and valve train.
flatrate
Car: S14 kouki
yeah i dunno very few people are getting impressive power out of stock heads... with reasonable boost and pump gas ive pretty much done everything i can think of to help this thing make power.. and its not even close to making what i expected
julio
flatrate wrote:yeah i dunno very few people are getting impressive power out of stock heads... with reasonable boost and pump gas ive pretty much done everything i can think of to help this thing make power.. and its not even close to making what i expected
I know its probably on the forum somewhere, but whats your setup/power output?
flatrate
Car: S14 kouki
RB25
AFI divided T4 manifold
3076r with 1.06 divided housing
greddy style intake manifold
full 3in exhaust
haltech ems 850cc injectors
bottom end is built.. stock head/cams
at 20psi it made 412whp and 320wtq id like to get close to 500whp on pump gas pretty far off
I did have a pretty large boost leak pre intercooler @ the BOV during the dyno... the engine is run on a map based setup so no maf
No idea what kinda power loss a boost leak will cause, i know its servere on a MAF car but its not a maf setup... havent dynoed it since the boost leak being fixed but dought it did much
my honda made 480whp and 360wtq at 18psi and pump gas on the exact same turbo..
RustspecS13
Car: '74 260z and '88 300zx turbo
Even with a map setup a boost leak will cause a big power loss. The ecu is seeing whats going in the engine, and the afrs and all that are right, except the turbo is overspinning for that boost. IE you might be loosing 5 psi (random number) and so the turbo is maxing out at 25psi, yet the ecu/engine only see 20, so it makes less power.
I would get bigger cams though, even just slightly larger.
~Alex
flatrate
Car: S14 kouki
RustspecS13 wrote:Even with a map setup a boost leak will cause a big power loss. The ecu is seeing whats going in the engine, and the afrs and all that are right, except the turbo is overspinning for that boost. IE you might be loosing 5 psi (random number) and so the turbo is maxing out at 25psi, yet the ecu/engine only see 20, so it makes less power.
~Alex
im curious to try some regrind cams cause there so much cheaper but havent deceided
I need to put the car back on the dyno to see if it gained power... id be surprized if it gained more than 15whp
