Tomei 260's
rossmac
What modifications need to be done if any to the head to fit these cams?cheersss
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Depends on the lift. Anything over 8.8mm I believe requires stiffer valve springs and once you get over 9 - 9.25mm you really should have solid lifters.
fabio240
Car: S13 with ca18det
What about the 260 8.8 lash cams that tomei has? does anything need to be changed for those?
dattodude
Car: CA18DET Datsun 1200 B110 Sedan
With 8.8mm lift and hydro lifters.. unless the springs/lifters are old.. the existing parts will work fine. Measure the springs/lifters and replace them if they are out of spec according to the FSM. Buying more stuff just means less money for petrol and speeding fines.
