NICONick wrote:Are S-Techs linear ? I think I'm gonna go with replacing the blues and going with the S-Techs.
Which linear springs would you recommend? (on my HP's)
*sigh*
Come on' man. Exar Kun made a suspension FAQ (in the wheel/tire/suspension forum!) with ALL the spring rates for the current kits available, he did all the work for you:
zerothread/11638
If you look in there, you'll see that the S-techs are progressively rated.
You can get what I have: Suspension Techniques, they are linear, and a good price (they sell them in pairs for some reason). SummitRacing stocks them i believe.
Do you have your stock springs/struts? I would put them back in and sell the Sportlines on Ebay, and with the money from that you can get the springs you want, and then sell the Blues, and get AGX's instead. I don't know how serious you are about driving and whether or not you autocross or 'drift' your car but you are hindering yourself with the Blues, they are only 'slightly' firmer than the OEM 240sx shocks and they're just not going to pair well w/ any stiff spring at all. At least w/ the AGX's you can crank up the firmness according to what spring you will be using with them, but again, i do not know what your plans are for the car. People can talk trash on aftermarket springs/struts vs. coilovers, but the fact of the matter is, you have to find the right match. There's a lot of crappy, spongey springs out there that are labeled as 'performance' that are in fact not.
Good luck.
