tokico shocks?
Que-45
Car: 03' Y34 Black/Black
Anyone know if the tokicos from my 93 will bolt right onto my 96? The rears look the same but not sure on the fronts
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
No idea for sure but I got this from stillen.com:
Application Notes Description Part # Mfg # Price 1990 - 1993 Q45 TOKICO PRM PRF FRONT 90-93 Q45 TOKHU2890 HU2890 $85.42 Buy 1990 - 1996 Q45 TOKICO PRM PRF REAR 90-96 Q45 TOKHU2892 HU2892 $72.99 Buy
Source: http://www.stillen.com/product...l=Q45
Q45tech
Rears are the same 90-96, however fronts on 94-96 have a different lower mounting pin because front oems were different stiffness.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
As noted, you would have to drill out the front mounting holes.
Que-45
maxnix wrote:As noted, you would have to drill out the front mounting holes.
thanks for the info guys. how hard of a job is it to drill the front mounting holes?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Drill press will probably help.
Raxephon
Car: '04 RX8...for the moment...
Why would you even bother?
If you're buying new, throw a few extra bucks in and get the correct size struts to begin with.
Drilling out the lower mounting point on the strut or filing down the mounting point on the hub are both non-practical compared with the minor financial variance between the correct strut and the earlier strut.
Don't get me wrong, I'm all for a little D.I.Y to save a dollar here and a dollar there, but if you do a cost/benefit analysis, you'll see that its cheaper(dollar-wise) to just get the correct ones to begin with.
Raxephon
As a side note my Q is a late '93/early '94 and it has the newer style lower strut mounts, so there is a good possibility that your struts from your '93 will fit your '96.
No way of really telling without pulling the front struts off the '93 and seeing if will actually fit on the '96.
I don't have access to a '96 or I would try it just for s*#ts & giggles.
