MAJOR difficulties with the strut installation. DAE, the pix you sent showed the spring/strut assy out of the car assembled: Is there a difference between the 90-93 and the 94-96? In your pix, the spring sets on the bottom perch of the strut and there is some sort of perch at the top as well, to allow assembly OFF the car. However, when I pulled mine, the shock shaft that extends into the trunk has no such perch, necessitating on-car compression of the spring to allow installation of the strut... MAJOR PIA. Not much room for a spring compressor in that fenderwell, and the control arms (?) get in the way a lot... If there was a different way to put the assembly together OFF the car, then I'm gonna be torqued...
My mechanic and I went through 2 12-packs of Corona and some bloody knuckles - But had a great time.
Any chance the fronts will be easier? Need some guidance on these, as the front NOW feels floaty. I LOVE the rears - Wish you guys ALL could feel a Q with the Blues... Nice!
