WingsNThangs wrote:The downside to that bonus is that you have to get your wheels aligned every time you adjust them to correct camber problems. Of course you don't HAVE to re-align, that is, if you don't care for unnecessary tire wear.
Are you quite sure about that? As far as I can tell, the AGX's are adjustable for bump but not rebound. The site isn't clear on this, so I may be wrong.
Edit: Not that the above has much to do with anything. Just an interesting bit of information.
I don't think stiffer bump setting (turning the knob) shouldn't affect ride height or suspension geometry enough to throw off alignment.
That poor little shock isn't going to be able to stop that coil spring from compressing, not matter what setting it's at. AGX's are OE replacements, no modding required.
I just don't see how adjusting the damper stiffer is going to throw off camber. Someone please correct me if I'm wrong.
