tokico d spec extension on g35 sedan
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
pae9132
Car: Modified 03 V35
This is for an 03 but should work on most sedans....take out rear seats by feeling under the front of the seat (butt) part until you fill the ring...pull the ring and lift up the seat...do this for both sides to take off the bottom....then undo the 2 bolts that are holding down the rear portion of the seat on each side of the car...then lift up on the rear portions and they will come off....you will see a soft rubbery cover on each side which covers the shock...it just comes right off and you can install the extensions....just make sure they are sticking out when you put the seats back on....ENJOY!!!!
TeflonG35
Car: 2003 G35 Sedan
This post would be awesome with pics *wink Wink* I always take out the back cushion when i'm at the track.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
