Jeff Williams »
https://forums.nicoclub.com/jeff-williams-u431.html
Wed Jun 09, 2004 2:57 am
The Tokiko Blues will definitely keep the car from flying all over the place. The air pressure in your tires, will make the difference in the initial bump.
If you go to 16" or 17' rims, then you will feel the harshness of the bumps.
I can tell the difference in 32 and 38 PSI in my tires. It rides like 2 different cars.
Do the Blues, upper links, bump stops, strut boots, and sway bar bushings.
Your backbone will thank you.
