maxnix wrote:What is a Strutmaster kit?
That shop should be avoided.
That bit of advise should be avoided!!!
Opinions, we all have one!! Yet since you do not even know what the kit is, how can you speak on it.
I have a Strutmaster conversion kit and it was recommended after seeing the cost involve in bringing the A system back to life. Yeah the recharging is not costly but if it is to a point where you have to do that chances are the other components need to be replaced too. Control arms, bushings and the like.
The shop that did the work adjusted the system and I have not had a day of issues with it. I have the T-blue shocks that came with the kit...... total cost installed was $1100.
I am satisfied and have had the conversion now for almost 2 years.That is a Strutmaster Kit, same thing as Infiniti sells, for a lot less money. So what is the problem unless you are just a purist? Even then if Infiniti sells it there can be no Purist? They made and designed the Q45a and even they see the need to offer an alternative to the $1400. a shock on the A.
Heres to STRUTMASTER.........And if you dont know, you better ask somebody! !
Nice to keep the A as an A but nicer to see a clean 14 year old Q on the road, instead of parked in a shop or someones yard.
