180fan »
https://forums.nicoclub.com/180fan-u3602.html
Sat Jul 14, 2007 8:48 pm
xxmarcusrxx, your sig is rather large and needs to be reduced in size.
Yes, too much - toe will chew through your tires, although probably not in a matter of miles.
You adjust the toe settings at an alignment shop unless you've the tools. But since you're asking how to adjust the toe, I'm guessing you don't. They do get expensive, and adjusting toe can change some of the other measurements. So yes, do take it to an alignment shop.
