TO4B.. what can i do with it?
Reno
Car: 89 S13, boosted.. RAWR..
hew-woaw Fellers :P
about a year ago someone gave a TO4b 50 trim .48ar.
and the compressor blade is slight chipped... -_-
but anyways. what do u guys suggest on upgrades.. if possible.
like if i can get a TO4E compressor and blade? i heard about some Big 60 or something upgrade? if i can upgrade the compressor where? :P TY
and Grammar Warlords (gtfo) TY
Modified by Reno at 1:37 PM 2/4/2009
Reno
i bump topic with this
Reno
Japanese/Chinese
this is what happens when u mix both
interested in her?http://en.wikipedia.org/wiki/Emi_Suzuki
can i put a TO4E compressor and blade on it?
Reno
Hello? any idea if the to4b is worth it?
480sx
Car: 1996 Pearl White 240sx
t04b is just a compressor wheel and housing. We have no idea what kind of backside that turbo has on it by you calling it a t40b, so there is no way to tell you what you can do with it with the information you'v given us. The compressor is fine for a ka, but again, no idea what kind of backside is on the turbo. What flange size is the housing?
If you want to get technical with it, take off the exhaust housing and measure the turbine wheel.
Reno
t3/t4 hybrid 50 trim .48 ar, compressor wheel is almost 2 inches. turbo maxes @ 325rwhp@ 21 psi?
due to broad research.
Reno
bump
eazye2000
Car: S13 KA-DET
Ack, jibberish to me. Not that I know alot or anything.
Just ditch it for something that we 'know' works. Try the sticky at the top of KA-T forum.
Reno
I've read the sticky many times, it doesn't answer my question.
Ive read that they're both very similar in performance.
basically i hit boost @ 2800 rpm if i do my calculations correctly.
basically can i swap the compressor and cover for a bigger 1...
