C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Tue Jun 29, 2004 12:00 pm
T88? Well, for the most part, at about any flow rate with a stock KA(stock redline), you'll never even get enough flow to make it past the surge line, regardless of how much boost you run. So essentially, you would be boosting entirely to the left of the surge line. For a small displacment motor, to effectively run a turbo this big, you would need to run a huge turbine to keep it from spooling until some extremely high RPM, and make sure the motor can both breath and stay in one piece at the RPM's where this turbo could be functional. Other options would be to use a turbo along with a boost bypass. But that kind of becomes a wasted effort in that all the energy you are now using to create this boost and airflow is being thrown out of the bypass until you see higher RPM's. There are some compressor inlets designed to allow you to tuna compressor within the surge by somehow circulating air back in front of the turbo when surge occurs. It's again a wasted effort, and probably should be limited to race cars. I forget what they are called. I'm also not sure how exactly this operates. I only remember the topic being touched upon many years ago in some article I read.
