To whom has the NSPORT KIT.....
C-Kwik
Turbonetics uses mostly Garrett Parts. It should bolt right up.
WDRacing
Yep, the turbo drain on 99% of the turbo's is a 2 bolt flange. Just a gasket and 2 bolts and your set.
WD
WDRacing
What turbo are you buying??
WDRacing
what are you paying for the turbo and DP??
DriFt3r
Car: Racing and Drifting
Do you guys know where I can just buy the Nsport manifold, turbo and downpipe? or just the manifold and downpipe because I have the rest already thanks
C-Kwik
The oil return flange should be the same. And even if it's not, making one would be fairly easy.
