To use an intercooler or not!!
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
lyon23
Car: 95 240sx
I planing on installing a turbo in my 240 swap. I want to run a single gt42 size turbo. I was thinking of 7-8 psi max. Will it be ok to not run an intercooler or is it necessary. I'll be using a 2 row aluminum radiator and an oil cooler to control temps. This will also determine turbo placement from driver side w/o or passenger with intercooler. If there is more info needed let me know so I can provide that.
LEMHEAD16
Car: '12 Genesis Coupe
'95 QofDOOM
'56 Chevy pick up
You really need to look at the compressor map to see what kind of efficiency you will get at 7-8 PSI. If the turbo is not pumping much heat into the air at 7-8 psi you would probably be OK. I would run an intercooler because once you have 7, you'll want 8, and once you have 8, you'll want 9........It's addictive.
Oil cooler and radiator will do little to control intake air temps.
XJared
Car: 06 Titan, 83 Z, 10 Z
Use an intercooler. A turbo of that size makes way too much heat to even consider it, even at low boost. And why would you get a 42R to run 8psi? They really don't come alive until the high teens. I ran 42psi on my Honda with a 42R.
lyon23
Car: 95 240sx
LEMHEAD16 wrote:You really need to look at the compressor map to see what kind of efficiency you will get at 7-8 PSI. If the turbo is not pumping much heat into the air at 7-8 psi you would probably be OK. I would run an intercooler because once you have 7, you'll want 8, and once you have 8, you'll want 9........It's addictive.
Very good and valid points. I will start learning about reading compresor maps. And it is addictive. It would be the same to run the intercooler or to add the meth injection. I know I'll be limited by the stock motor but I do want to try 10 psi with a really good tune.
XJared wrote: And why would you get a 42R to run 8psi? They really don't come alive until the high teens. I ran 42psi on my Honda with a 42R.
More power at lower boost. This turbo size will provide more volume at that psi than a smaller turbo with the same exhaust turbine.
kingkilburn
Car: '93 240SX
That does not mean it will do it well. It's all about response and efficiency.
Nealoc187
Car: 95 Maxima
That's not how it works. You're going to be almost off the map in terms of efficiency. Ridiculous. You should really rethink what you're doing.
lyon23
Car: 95 240sx
kingkilburn wrote:That does not mean it will do it well. It's all about response and efficiency.
Nealoc187 wrote:That's not how it works. You're going to be almost off the map in terms of efficiency. Ridiculous. You should really rethink what you're doing.
That's why I said this..
lyon23 wrote: I will start learning about reading compresor maps.
XJared
You didn't specify, but I assume since you're posting in this forum that you're swapping a VH45 into your 240sx. Two big questions here relate to your end result. Will you be doing internals? and What are your power goals?
lyon23
Car: 95 240sx
Power goal is 450-500. I have 2 engines a stock one with 130k on it and a second one to build slowly with pistons, rods and arp fasteners.
tacozzz
check this out
http://www.turbofast.com.au/TFmatch.html
i use this whenever i think about a turbo selection but it should be used as a GUIDE and not a definite selection but
for a vh45de 4600cc 7000 redline, non intercooled, and 8lbs of boost you might make 517bhp with a gt3076 with a 1.06 turbine housing.
then click on the intercooled box and you only have to run 6lbs of boost to make 510bhp.
look here
http://www.ctsturbo.com/products/Garret ... 72-25.html
id say run the gt3076 with no intercooler if those are your goals.
and you say you're going to build it with pistons, rods and arp....i know mazworx sells a piston set but any machine shop would be able to order some from je or whoever, but has anyone found any aftermarket rods like eagle or can eagle make custom ones for the vh and arp fasteners, the mains already have studs from the factory has anyone looked into part numbers to replace those and put together a kit for head studs? how about arp rod bolts for factory rods?
you should really rethink your gt42 turbo unless you want to turn the nonintercooled boost up to 18psi and push out a theoretical 654bhp
hannibal
Car: Red Line to Glenmont
No way is a GT3076 a good single turbo. Two of em would be sweet.
To answer your original question, an intercooler is certainly a good idea. That GT42 seems like a good fit. Its not breaking a sweat at all, but that doesnt mean its a bad turbo for the VH45. Take a look at this thread. Lotsa discussion about turbo sizing. turbo-sizes-t491095.html
XJared
Whatever turbo you end up with, get the biggest frame and a/r exhaust housing available. You'll need it with the big VH displacement.
Return to “VH45DE / VK45DE / VK56DE Forum”
