nyvenom30 wrote:well putting a 3.5 means putting in a new computer and lots of other things... i think it would be easier to get another 98 maxima take a few select things.. part some of it and than take it to the scrap yard... take the engine out have it magna fluxed along with the heads.. get the custom piston from ross and a master rebuild kit from rpm... vb mod and tanny rebuild from level 10 transmissions, and torgue converter, and super pump... as far as whose putting the block togather well i need to find someone with a machine shop that knows what there doing.. im not sure what turbo kit, injection kit, iginition kit, multi-spark unit, as far as i understand i need low compression spark plugs, new radiator, transmission cooler, and seperate turbo cooler, not sure about the mevi, i might go for the 00v1 even oth it not direct fit.. as far as tuning the car i need you to be suspecific.. cause im not understanding.. oh and another thing where can i get radial arms...
You dont have to swap computers to put a 3.5 in.
