Now im fairly new, but I thought I had read that you cant use the T56 from a GTO, you have to use one from a Camaro/Firebird because of where the shifter is? Did you do a special modification to do this, or does this only apply to certain year 240's?cnichols wrote:I first used the Camaro T56 6speed, but upgraded to the GTO T56 6 speed because it has the same gearing as the Corvette and the better synchros as well.
GTO transmission works just fine...the outer dimensions are identical to the F-body T-56, it just has a few different ratios (same as the Corvette) and better synchros. You just either use the shifter from a GTO or replace the shifter cup at the end of the linkage with the F-body one and use an F-body shifter. Very simple and very easy to change if necessary. Whoever said you can't use the T56 from a GTO is a moron and needs to shut up and stop spreading false information because I've done it and it's been working for 2 years now with ZERO issues.prestage3ek wrote:Now im fairly new, but I thought I had read that you cant use the T56 from a GTO, you have to use one from a Camaro/Firebird because of where the shifter is? Did you do a special modification to do this, or does this only apply to certain year 240's?cnichols wrote:I first used the Camaro T56 6speed, but upgraded to the GTO T56 6 speed because it has the same gearing as the Corvette and the better synchros as well.
