Grandpa01 »
https://forums.nicoclub.com/grandpa01-u53001.html
Wed Jan 03, 2007 3:39 pm
How did you route the harnesses on in both fenders so they don't rub?
For some unholy reason, I decided to route the driverside through the fender brace. Yes, I cut every single wire on the harness and soldered it back together after routing it through. It took forever, but now there's no worries about rubbing.
The passenger side was much easier as the entire harness unbolts from under the dash at the ATC, ecu, speed controller thingamajig, and wiper stuff. It was even easier after I removed everything that had to do with the automatic since I'm 5-speed'd.
Anyway, it wasn't fun, and I was wondering if anyone else had joined in the un-funness. If, by chance, anyone else hates themselves to an absurd degree, I'll post up pictures of what I did to guide you on your path to sadism.
